Nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Testimonial: "yes, it did get corrupted by a software and I had to give it to some workers at nokia to fix it, I lost the info on the phone (except memory card)"
But when do I type in the code. First I see a Nokia logo and then the white screen and in seconds the mob switches off....
i tried it, and it made a sound but did not change
the same happened to my phone too, i am trying to do a hard reset but not changing, nothing is showing only the nokia words than blank screen then the phone goes off.
plz help..
My nokia 5130 not working it software not works when its switched on it comes white screen then how to update it
SOURCE: Nokkia 5130 -screen goes white
It was due to the internet use in your phone, you need to reformat your phone, try this *3call button, must press in same time then, switch on off until you will seethe select country. or go the technician.
SOURCE: nokia 5130: when I try
Try pulling the batter off of it and have someone test the battery for voltage and amperage. then try cleaning all the connectors and replace the battery. I had a phone that randomly dies and it was because the power connection was dirty.
