SOURCE: kg800 lg chocolate
Hi please follow below given steps Insert sim > Turn it on >do Slide up phone> Type 2945#*#> ENG. Mode menu should appear>Go Down to Factory Reset Select it(Wait for few min.)> This will reset the phone back to before the Phone was locked to a network> The phone will automaticaly Restart> Now insert Any simcard(Not tested with 3 sims)and the phone should turn on normaly> The phone is now unlocked and you can customise the setting as you like. Gizmo1
SOURCE: LG KG800
- Turn on phone
- On home Screen, Slide up phone
- Type 2945#*#
- ENG. Mode menu should appear
- Go Down to Factory Reset Select it, it may take a few minutes to reset
SOURCE: lg puk code
that sounds like a sim card problem....you should contact your mobile provider or look in the envelope that the simcard came in to and you will see two puk code numbers enter either one and follow the step by step instructions.
SOURCE: changing the housing on lg kg800
Try these they have shots to help you..
http://howardforums.com/showthread.php?t=1180374&highlight=kg800+flex+cable
http://www.formymobile.co.uk/Dismantle/lgchocolate.htm
Hope that helps :o)
SOURCE: security code for LG KG800
There is no way for someone else to your your security code, if you didn't change it from default it is either 0000 or last 4 of your number. If you changed it and forgot use 277634#8# as soon as you enter it will open an engineer's menu and allow you to reset phone which will set everything back to default then code will be 0000
