I have a Quantary zoom lens 28-90mm "for Minolta AF". It fits my Sony alpha350 camera, but the camera does not recognize it - says there is no lens. What's up?
Re: I have a Quantary zoom lens 28-90mm "for Minolta AF"....
Fitting is not always the solution. It is the software which recognises the hardware attachements. Either upgrade your camera software or use only the manufacturer recommended add ons. [email protected]
Quantary makes lenses for a variety of cameras. A lens for a Minolta, for example, will not fit onto a Canon. Assuming you get the lens with a Canon EF mount, then yes, it is compatible with a Canon digital SLR.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
