AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Our AEG Favorit Sensorlogic has had no power to it for an indeterminable period of time - we recently moved into our new house to discover this. Now with power it appears to start up ends up with an intermittent beeping. When opened no water has been run through.
How can we get it to work, or does this need professional assistance.
Anonymous
Level 2:
  • Expert 174 Answers
  • Posted on Jul 22, 2010
Anonymous
Expert
Level 2:
Answers
174
Questions
Helped
126418
Points
483
If u just reinstalled mke sure you removed the blancking plug from the drain spigot . simple but happens a lot.
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Mar 26, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512489
Points
12435
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
1helpful
Are error codes standard for the same brand/ different models ? Are they standard between brands ? I have a AEG dishwasher model favorit 50879 sensorlogic that gives an error code.
Some companies share generic codes like 'Lw', for low water level or 'DL' for Door Lock. This might help, there are other sites when Googling 'make model error codes'.
AEG Dishwasher Error Codes ' Dr. Dishwasher
www.drdishwasher.com > manufacturer > error-codes
Error/Fault Codes for AEG Dishwashers with an LED Display Fault Code ,10 Symptom: Dishwasher not filling with water. Go to: Why is My Dishwasher Not Filling ...
AEG favorit sensorlogic has no power.
Electronic is protected against short circuit throught out VDR - voltage dependent resistor which is located on the electronics. Unfortunately, when this happens usually get hurt some other component part or burn printed circuit boards.
Any intervention on electronics requires qualified person otherwise there is the risk of fire or electric shock.
Dado
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
1helpful
AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Jul 31, 2009 • Dishwashers
3helpful
2answers
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
