The LE code indicates a motor overload. The washer will not spin to avoid damaging the unit. First unplug the washer and let the motor cool for 30 minutes. When you plug in the washer, check if the unit has been reset.
The error often occurs if you use a non-HE detergent or too much detergent. In that case, do a Rinse and drain steps. Set the Spin Speed to No Spin by pressing that key several times. When that finishes, open the door and remove all of the clothes in the tub. Close the door and set the washer to Rinse and Spin. Run this program several times until you see no suds in the wash tub. If the LE code returns when the washer is empty, check the drain pump and filter for foreign objects. The error can also occur if you wash too many items at once or too heavy a set of items. Try doing a smaller load in the future.
If the error persists, then the tub motor, bearings, motor shaft or wiring may be damaged. Here is the parts diagram and one vendor's list of the replacement parts:
http://www.searspartsdirect.com/lg-washer-parts/model-WM1814CW/3204/0153200/K0810333/00002.html . If your washer is under warranty, contact LG.
I hope this helps.
