What is the difference between the different model numbers for a 1/2 "dewalt hammer drill. for instance dc925,950,988, k,a,r ? Is there a reference somewhere to explain them?
SOURCE: Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
SOURCE: dewalt dc 988 drill housing
If you are in America/Canada go to dewalt service net http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1. make sure you check the type number as there are some variations across the model range. You should find the type number either just after the model code or on the top right of the rating plate.
If in U.K. then go to https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB.
You should be able to ID the part and find a dealer from these sites.
SOURCE: removing the dewalt DC925 'rohm' chuck
It should have a retaining screw as far as I know. It may be a torx head in this machine though. Normally left hand thread screw, then normal thread for the actual chuck. It's always worth tightening the chuck a bit before removing the inner screw as it can put pressure on it and make it harder to loosen.
SOURCE: i have an 18v dewalt hammer drill dc925 and cant
It's one of the settings on the clutch ring. Or do you mean it won't turn there?
SOURCE: all i need is the schematic for a dewalt hammer
go to Dewaltservicenet.com and in the middle of the page type in your model number and you can download a breakdown for this tool. If I have answered your request would you please rate this response accordingly.
