Acer AL1916W 19" LCD Monitor Logo
Posted on Mar 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
He message is ANTI THEFT MODE IS ENABLE. When it
Message is ANTI THEFT MODE IS ENABLE. When it comes on the system , it becomes turned to blue color but system will works normally. the warning message is appeared in the middle of the computer. when i switch off the monitor after it will come normally. how to disable this anti theft mode.
Catalin Turcu
Level 3:
  • Acer Master 4,924 Answers
  • Posted on Mar 27, 2010
Catalin Turcu
Acer Master
Level 3:
Answers
4924
Questions
0
Helped
1232102
Points
13383
Try to go to bios by pressing f2 on start ..and after that choose optimal factory defaults from the list ...it will be somewhere there a line named exactly like that ..after chooseing it ..press f10 to save changes..and reboot ...if it set from there it will go away..
HOW CAN I DEACTIVATE ANTI THEFT MESSAGE ON W204 MERCEDES BENZ C CLASS. IT WONT START?
How do I get my Mercedes out of anti-theft mode?
Look for a button that allows you to slide the physical key out of the fob. Step 2: Turn the vehicle key to unlock the car door without releasing it. Hold the key for 30 seconds in this position. This will signal to your car's system that you have the right key, and will enable you to bypass your car's alarm system.
https://www.google.com/search?q=MERCEDES+BENZ+C+CLASS+reset+security
2helpful
2answers
2005 Chevrolet Equinox after starting it immediately shuts off
Sounds like a security system problem. Do this, turn the ignition switch to start but don't start the engine, then leave the switch in the run position, watch the theft light it will be on steady or flashing, wait for the light to change then turn the switch off then repeat up to 2 more times, it takes about 10 minutes per cycle don't try to hurry and if the car accidentally starts and quits start over. Occasionally the vehicle will start and run after the second try but don't count on it, I hope this helps, take care.
Need to know where the tdm is on a 1997 Cadillac deville can't get security system to shut off should I replace ecm ? Please help
It's hard to get the SECURITY light to go off when you don't know how it works ! Replacing the PCM could cause you more problems too . If a replacement PCM is being installed it must be programmed (flashed) using the latest Techline programming procedures.
Having the vehicle check for DTC ' S - diagnostic trouble codes would be the first step.
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
DTC P1630 Theft Deterrent Learn Mode Active
DTC P1631 Theft Deterrent Start Enable Signal Not Correct
DTC P1632 Theft Deterrent Fuel Disable Signal Received
This anti-theft system does not use a TDM - theft deterrent module . The instrument cluster is the controlling module . Look at a wiring diagram here
http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model engine . Then under systems click on body & accessories , then in subsystem click on security / anti-theft . Click the search button , then on the blue link .You mite be able to do a by-pass if the contacts inside the key lock cylinder is the problem . You can check it with ohm meter . The key has a resistor pellet on the side , you can check the value with ohm meter , find the two wires under the dash at the steering column . Two white wires inside a yellow or orange sheathing . There are videos on youtube !
2helpful
It makes a blue screen every 20 minutes and says anti theft alert so i unplug it for about 5 minutes and then it works and does it again
To turn off anti-theft mode:
1) Turn off the monitor
2) Press and hold the menu button
3) Turn on the monitor
Release all the buttons
that should disable the anti theft mode
31helpful
2answers
Anti theft mode enable this message comes in my system pls give me solution it comes after one hour
first power off u r monitor
then press and hold menu button on the monitor then press power button on monitor
3helpful
How to solve anti theft mode enable
my acer monitor showing anti theft mode enABLE
3helpful
2answers
Car starts then stalls due to the anti theft system need info on reset
you should be able to use the key to unlock the driver door or the back hatch and that should disable the anti theft.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
