The reaset code dose not reset it.
This means that the fusing unit has a problem. Turn off the copier. Open the small side cover on the right of the fuser unit. You will see the wire connectors leading from the unit and carefully remove them.Open the three screws holding the unit and remove it, check the heater lamp continuity if out replace the lamp. Clean the thermistor and return the unit by reversing the removing process. Now try the code and it will work.
