Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
Posted on Mar 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello,We have an Hoover Mach 5 Cyclonic vacuum that has no suction. We have cleaned and checked all hoses, belts & filters. Please help us.
Robert Pagliaroli
Level 2:
  • Expert 294 Answers
  • Posted on Apr 21, 2010
Robert Pagliaroli
Expert
Level 2:
Answers
294
Questions
Helped
101109
Points
540
With this model, remove the dust tank, and turn it on, check for suction at the lower intake. If you have suction, install the tank and remove hose, and check for suction there. keep following until youn lose it. Then you problem will be between those 2 areas
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Red light indicator comes on with suction only
Hi there Christy! It sounds like you possibly have a clog in your main hose. To check the hose for clogs remove the hose completely from the vacuum from both ends. Use a broom stick or something similar to loosen and remove any clogs from the hose. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose. Hope this helps!
1helpful
2answers
Hoover Freemotion Pets 200W has lost most of it's suction!
if you take out the dirt cup at the top there should be a half moon orange that releases. inside of this half moon is a washable filter. rinse with warm water and let it dry completly before putting back into the machine. this should restore your suction. hope this helps.
2answers
Hoover Mach 3 (Fusion): Dirt Will not enter dirt cup
The dirt in my vacuum keeps getting stuck into the hose and dosent reach the chamber, its a constant problem even if i clean out the clog!!
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
3helpful
I have no suction with my Hoover Mach 5 vacuum.
I had a similar problem. Two things to try. There is a lock symbol on the canister you need to ling it up with the mark on the top (the silver part has a line on it). It can be assembles 3 different ways. Also I over looked the sticker in the back of the canister compartment indicating a filter in the top of the canister compartment. There is an orange lever there to release the filter. Hope this helps.
4helpful
2answers
My hoover mach 6 bagless overheats, shuts off for about an 1 hr will run again, all filters are clean, no blocks in hoses, how can i fix this problem
This is telling you that there is poor air flow or a blockage somewhere. To simply check for proper suction, remove the accessory hose to see if there is normal suction, if not then your problem is further in the unit. Troubleshooting from there will tell you where the problem is. Another possibility is that your thermal overload circuit is faulty. in this case a pro vac shop needs to service the issue.
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 • Vacuums
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
