Our TV won't come on either. When we hit the power button on the remote or on the TV itself, all it does is go click, click, click pauses a few seconds and goes through the click, click, click process again until we finally hit the power off button. Is this TV repairable? Will it be expensive?
Thanks!Our TV won't come on either. When we hit the power button on the remote or on the TV itself, all it does is go click, click, click pauses a few seconds and goes through the click, click, click process again until we finally hit the power off button. Is this TV repairable? Will it be expensive?
Thanks!
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Same thing here....RCA tells me to count the times the light flashes as it apparently is set to "tell" you what the problem is.......3 to 5 flashes means your lamp is messed up.....they are over $300 to replace!
the rca itc222 chasis has a processor that shuts the set down when it detects a problem for Safety. it can be one of about 30 problems. the computer also records the errors in memory and a technician can interface with a computer to read these errors. after the set attempt to come on 3 times then the set locks up and you have to unplug to reset.
There is probably a short or a near short loading the power supply circuit, a leaky capacitor, shorting diode, transistor,IC,LOPT etc. Have the set checked by a technician near you.
I was wondering if you have looked through your service manual or owners manual for troubleshooting the problem. If not you can get service manuals online at http://www.servicemanuals.net/results.aspx?type=SM&brand=424&model=F35750ST
Quinn
Thanks!
same problem, it does it three times and stays off, can you help?
