Question about Proscan 42LA45H 42 in. LCD TV
40'' proscan lcd will not turn on
I have a 40'' proscan lcd less than 1 year old the power supply would ring when the tv was off it was unpluggeed while on vacation for a week. Now the power supply will light up but it will not turn on by remote or buttons on tv ????? did the power supply take a **** Thanks Jeremy
  • 7 Answers
Could of gotten voltage surge
Try anther outlet
Posted on Dec 05, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Posted on Feb 06, 2009
Anonymous
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
Anonymous
  • 3 Answers
SOURCE: I have a Proscan 40 inch LCD tv and i can't
I use a comcast remote for my 40lc45s. I called proscan @ 888-977-6722. They were very quick with the answer. The code requires 5 digits. 10178, 10029, 10030, 10019 all worked right away.
Hopes this helps you out
Posted on Jul 08, 2009
Mike Sandner
  • 20 Answers
SOURCE: Proscan 40" LCD-Screen Freezes
They actually state that you have to unplug it and replug it in to fix this problem in the owners manual so it's not just a isolated issue. I to have this problem daily now and this is the 2nd set after returning the first one due to same reason.
Posted on Oct 12, 2009
How to reset proscan tv
Possible power supply problem,capacitors may have bulged and leaked restricting the supply from starting.
Len
Sep 08, 2014 | Proscan 40LC45Q 40 in. LCD TV
When I turn on my Philips LCD TV, It just stays on the "philips" logo home screen...the picture never comes up. Also, I have tried to unplug it form the wall and I also removed the power supply cord from...
It is possible that the TV was hit by a small power surge, and the processor has some garbage in it, and you need to leave it unplug for 40 MIN, and that will reset back to normal. Make sure for at lease 40NIM,
Oct 16, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
I have a LG LCD TV 42LB1DR-UA for 4 years and I am going on my second power supply. Last one was replaced less than 1 year ago. LG says there has been no recall but I can not see paying $200 per year to...
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
Aug 03, 2010 | LG 42LB1DRA 42 in. LCD Television
When I turn on the TV the screen comes on for a couple of seconds and then it goes off. After trying several times, it will stay on. It is getting worse ande I assume it will fail completely soon. It is a...
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 05, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
I have the 26 Proscan tv and the power will not come on. There is no light and I have checked the circuit box and everything is fine with that. Help! this tv is less than a year old.
You need to take this unit in for service. You have had a failure in the power supply board and now the unit will not power-up. This requires the help of the service center to thoroughly test the unit and determine the problem You can find customer support for PROSCAN at this website. www.oncorpus.com. Go to the support section and tell them you problem and find out where you can take it for service. The customer service telephone number is 1-888-977-6722. I hope this has helped you with your problem.
Apr 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Dec 03, 2008 | Proscan 19LA25Q 19 in. LCD Television
Proscan 42LA45H 42 in. LCD TV Logo
205 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
