I am trying to program a Universal remote to controll my Tv but am unable to locate the four digit program code to g.o into the new remote for a Sony KDL-52XBR6 Tv. Can you help? Thanks
UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
013/ 054/ 055/ 060/ 065/
067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
According to your description here, I understand that your RCA TV will only respond to 4 digit set up codes. If so, try the codes for your RCA brand, by avoiding the first 'Zero' of the five digit code. For example, it the code is, say '08765'. it is actually a 5 digit code. To make it four digit, just cut off the first 'Zero'. the the code will change to '8765' and is a four digit code. Four digit universal remote codes to check with RCA TVs are
Hello
Setup code for Sony TV with Vizio Universal remote control is [ 0000 ]
The reomote control is pre-programmed to work with all esisting Vizio TVs. If you want to set up it with Sony TV, do the following.
1. Manualy turn on the TV.
2. Press the [TV2] button on the remote control.
3. Press and Hold the Setup button until the LED light flashes twice.
4. Enter (0000) using the number buttons. If the code is accepted the LED flashes twice after the last digit is entered. If the LED does not flash, repeat steps 2 through 4 once again.
5. Point the remote control at the tV and press POWER button. The TV will turn OFF.
Other four digit codes to check for Sony TVs are: 0128/0013/0002/0071 & 0380.
If code [0000] does not respond with try other codes. Repeatsteps 2 through 4 once again after entering each code listed. The code listed with Vizio universal remote control with Sony TV is [ 0000 ].
OK.
Hello
Three digit universal remot codes for Sony TV are:
002/ 006/ 071/ 128
Four digit universal remote codes for Sony TV are:
0128 0013 0002 0071 0380
Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
