Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
It shows Sim Error or else Invalid Sim...Or even though Sim Inserted it asks "Insert Sim" If it says anyone of the error like that means Your Mobile is Locked To Network ..You need T Unlock it to insert other Network Sim GSM Sim Card.... It may locked to some Network....You can get the code here http://www.superunlockcodes.com/supported-phones/rs12wp7/ and Unlock the Mobile from the Network Lock.... I hope..You got solution...
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
No SIM card inserted or inserted SIM card is damaged
Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
This problem is due to your phone's sim card IC malfunctioning. It may get damaged due to phone dropping gently into rough surface and its crystal structure may break due to it.
for any queries
mail to [email protected]
well... seem like you phone has got locked from the network may be accidently in case of stolen better check you service provider and if they say every thing is fine try to flash your mobile .it has some perticular number to flash it try these number *#7780# (password 12345)
