Kodak EasyShare DX7590 Digital Camera Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory card requires formatting
The camera keeps asking for formating the memory card. Inspite of giving th einstruction to format it comes back to the same message. Hence I am unable to operate the camera
pictureman4u
Level 2:
  • Expert 132 Answers
  • Posted on Mar 28, 2010
pictureman4u
Expert
Level 2:
Answers
132
Questions
0
Helped
43954
Points
329
Have you tried a different card, that may help. Plus, there are cameras that will not "like" certain cards. If the card is...let's say...an 8 gig...some cameras can't read that or even write to it. Try a different card and a 1 or 2 gig card too. Good Luck.
Memory card will not format
If other memory cards take the format then your card is fubar.
2helpful
Camera tells me "memory card requires formatting."
Your memory card is larger than 2GB, isn't it? The CX7330 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card. While SDHC cards will fit into the camera, they are electronically incompatible and won't work in the CX7330.
Can no longer copy from internal to memory card. Keeps saying "Memory card requires formatting." When I choose "continue" the camera tries formatting then goes back to the original screen saying "Memory...
In the manual, page 21 & 21 describe how to use the camera to format your choice of either the memory card OR the internal memory. If you format the internal memory, images stored there will be lost.
Once you format in the camera, you should be able to use the card if it is no larger than 2GB. It appears the camera does not support cards greater than 2GB.
Please rate this reply - good luck!
1helpful
My kodak easyshare c180 wont read a memory card and keeps saying memory card requires formating. When I format the card it just asks me to do it again
You should probably get a USB card reader, take the card out of your camera, put in the card and connect it to the computer. Then try formating the card through Windows using the FAT file system (not NTFS).
What steps have you taken to format it?
My camera wont format card
The card needs to be formatted in the camera, not on the computer. Try going into the camera menu and find "reset"...follow the on-screen instructions.
LEXAR 4GB SD MEMORY CARD FORMAT??
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
