Put new 8GB card in tells me no images in Favorites, Press Revieew for current imagees, Memory card requires formating, continue, Formating will delete everyting on memory card, continue Formating, goes right back to Memory card needs formating. Tried with two or three, it will not. What do I do?
Hello my friend.
Try this tool which you can download clicking here.
It can solve your formatting problem.
- Download the file.
- Plug your memory card into your PC.
- Run the "exe" file that you downloaded.
- On the program menu select your device (memory card).
- Select FAT32 as file system.
- You may give a valid volume label.
- Uncheck the "Quick Format" option.
- Then start formatting your memory card clicking the start button.
This formatting will delete all the files in your memory card.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
NOTE: To download the file on the opened web page, see the picture below:
NOTE 2: Sorry for this extra note. I created my own site for you to be able to download the files easily which I uploaded for you.
Because the other linked web pages may have troubles and need extra explanations.
Now you can easily download the file from here
that I mentioned in my previous messages.
Thanks.
