Re: Unit continually powers up on and off but no picture
This is a common problem. Your power supply needs some repair work. I have a tutorial on this repair in my Tips & Tricks, check it out if you wish to repair it yourself. I hope this was helpful, best wishes.
Two main reasons flash is used over continuous lighting.
Power. Lighting a scene for minutes uses much more power than lighting it for a fraction of a second. You may have noticed that most continuous lights need to be plugged in to a power supply, while most flash units work with small batteries. It may not make much difference if you're shooting indoors in a studio, but if you're out in the field and have to move around, it can get difficult lugging all that gear around.
Duration. A flash unit provides a very brief flash of light while a continuous unit is, well, continuous. A flash can freeze action much better than just using the camera's shutter. Try it yourself sometime: turn on the lights in the bathroom (and/or bring in your continuous light units) and take some pictures of a dripping faucet. Now turn off the lights and take some flash pictures of the same thing. See the difference?
take a hair dryer with back off and heat specific areas unit you find the location that is causing this, either main board or power supply are possible.
Remove the power from the unit for a minute. Plug in and see if it works. If it does great if not continue.
There is a possibility that the LCD Lamp blew. To check this, turn the unit on. Look really close at it for a picture. The picture will be dark adn hard to see from a distance but it would be there if there is no damage to the main components. If there is a picture than either the lamp or inverter went, you will need to have it serviced or replace the unit.
If there is no picture at all then your unit may have had the tuner board go in it. This is a service only option. Best thing to do is take this to a tech shop.
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Power off the All-In-One (AIO) off and remove the power supply from
the back of the unit. Wait 30 seconds. Then reinsert the power supply
and power the AIO on.
Did the error message return? Yes: Continue to step 2. No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
Power off the AIO and remove the power supply from the back of the
unit. Open the scanner cover and check the scanner glass for
cracks and the scanner casing for cracks. Close the scanner lid. Open
the top cover of the AIO. Using the carrier belt, move the cartridge
carrier to the middle of the unit. Remove both cartridges, close the
top cover, reinsert the power supply, and power the AIO on.
Did the error message return? Yes: Continue to Contacting Lexmark. No: Continue to step 3. 3
unit. Open the top cover of the AIO. Using the carrier belt, move the
cartridge carrier to the middle of the unit. Insert the color
cartridge, close the top cover, reinsert the power supply, and power on
the AIO.
Did the error message return? Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4. No: Repeat step 3
and install the black / photo cartridge. If both cartridges are
installed, attempt a test scan. If the error message does not
reappear, the error is resolved. 4
cartridge carrier to the middle of the unit. Remove the color cartridge
and insert the black / photo cartridge. Then close the top cover,
Did the error message return? Yes: Repeat step 4 with another black / photo cartridge.
See if this helps
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
No: Print a test page. If the test page prints, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the All-In-One (AIO) on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black cartridge. Close the top cover, reinsert the power supply and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
Did you resolve the problem ?
