Washing Machines Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer won't start. was drying a load and had a pair of tennis shoes in with the clothes. It stopped and now won't start back up. All lights, beeps etc. seem to work fine just won't start.
  • Anonymous May 11, 2010
    Is it making any noises? What is the make and model of the dryer? Is it electric or gas? When was the was the last time you used it with no problems? Have you recently noticed that you cloths are NOT drying in the same amount of time they use to, IE - you have to run the dryer 2, maybe even 3 times to dry what you use to dry in 1 cycle? What is the position of the dial? Is it humming? Is the door close completely - Any obstructions that would keep the door from closing all the way?
Jim
Level 2:
Novelist:
  • Expert 101 Answers
  • Posted on Mar 29, 2010
Jim
Expert
Level 2:
Novelist:
Answers
101
Questions
Helped
36063
Points
204
As silly as this seems, did you make sure the door is completely closed. This is a common problem when drying tennis shoes. One time when I was living in an apt. complex, I went to check on my laundry, and my shoes were lying on the floor (with a couple of other fabrics). I then stood by and watched the remainder of the cycle, and next thing you know - the door opens up and throws out my shoes. Never would've believed it unless I seen it with my own eyes. I would turn everything off, and then go through your regular routine. If this doesn't work, feel free to contact me - and we can go to Plan B...:) Good Luck to you, Jim
  • Jim May 14, 2010
    I'm not sure if you found your problem, but I just received your comment on my page - and wanted to know if you found the problem. If not, let me know. It sounds like we'd have to go to plan B. And that means its probably the switch that is connected to your dryer door. Once you open the door, its up in the right hand corner where the door opens and closes. These switches are famous for going out, and they're easy to change. They're about a $15.00 part too. Anyway, if you've found the problem great! If not, then feel free to let me know and I'll help you through it. Best of Luck to you! Jim
1helpful
F&p gas dryer thumping noise when turned on. sounds like tennis shoes in the dryer.
Please check the roof first.
Then,
You have a part of the dryer has broken and is slapping the inside of the machine.
Please do not use the dryer again until it is repaired.
I say this because of the danger of fire, from the gas flames that dry the clothes.
God bless your efforts.
Apr 03, 2018 • Dryers
Dryer is growling when spinning heavy loads.
The bearings may be gone, but I don't know how old your machine is or the brand. If it is over 8 years old, consider replacing it. Maybe get an estimate from a repairman who knows your brand.
Jun 09, 2015 • Dryers
3helpful
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 • Dryers
4helpful
2answers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Dryer won't start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
1helpful
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
1helpful
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
I have a Neptune model MDE9700AYW dryer that wont start
Check to see if the little tab in the door jam, which causes the dryer to turn off, is broken or bent. If its bent you may just need to bend it back.
1helpful
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Alexander
vince
