why not buy the correct power pack
matching the power needs of you puter.
each puter needs a watts level, do that or more never less.
only hp.com spec tells you what you need,
its in the service guide for you PC.
take out the battery
now run OFF LINE pack
run now? good, does it drop dead if you gently
wiggle the plug at PC port> not moving pack and its cable.
yes, then the PC has a bad power port end cause.
if it is the PC power jack bad
you will never fix it. its real deep and takes totally disassembly to reach.,(done many and do no teach LT guts to anyone)
amazing HP.com has your books, and is always there.
read them it specs it out.
yes, power packs go bad, 3 ways, dead, weak, or intermittent.
all do in time, (max life is about 20years,less if overloaded, as i bet you did)
if the PC needs, 50w, do not put in a 30w. use 50 or 75 or 100w
see? or it overheats .the pack,
here is your page (OP)
seems very very old, HP, is fighting me...
needs 19v at 90watts,
$8 to learn what is bad, is this too much>?
old XP LT built in the 1990 its very very old and slow.
256mb ram wow. Celeron ouch.
https://www.amazon.com/Adapter-Supply-Charger-Compaq-Presario/dp/B002V1CWZM/ref=sr_1_1/153-8354350-8800969?s=electronics&ie=UTF8&qid=1489601394&sr=1-1&keywords=compaq+presario+2596us
