SOURCE: my ice maker doesn't make
The knocking is the compressor either trying to start or shutting down... the mounting frame has cracked or the bolts came loose...
there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
I appreciate your post, friend!
Based off what you have described your Frigidaire refrigerator's icemaker is making knocking noise. This could be due to your water valve or motor. Since it is difficult to pinpoint the cause of the knocking noise I would suggest having a professional technician out to perform an accurate diagnosis. This will help you avoid any unnecessary part purchases. Good luck. -Matt
