This is commonly caused by a blown Thermal Fuse. The fuse is a small white component mounted on the blower fan assembly. There should be two wires running to it. UNPLUG the dryer and disconnect the component wires before taking any resistance readings. You should read something close to 0 ohms with a multimeter if the fuse is good. If the fuse reads bad, you must replace it.
The location of your blower fan housing depends upon the MODEL NUMBER. Since you posted no model, the easiest way to determine where these components are is by the location of the dryer lint screen.
If the lint screen is on TOP of the dryer, all your heating circuits are BEHIND the dryer. Just remove the back panel to access. The blower fan housing will be located on the lower left hand side.
If the lint screen is in the DOOR of the dryer, the heating circuits are INSIDE the dryer cabinet under the drum. You will need to remove the lower toe panel under the door for access. If the dryer has a solid front with no lower panel, you must lift the dryer topand remove the entire front panel for access. The blower fan housing is on the left hand side of the cabinet under the drum.
The following link can give you some more guidance on dryer no power issues:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Refer to the section that explains the possible components for "Dryer Does Not Run At All". The Thermal Fuse is the most common cause, but there are other possibilities to consider.
Now...if the thermal fuse has blown, it usually blows for a reason. The most common cause is poorly installed, kinked or clogged exhaust vent ducting. I would strongly recommend you thoroughly inspect the ducting, air blower and cabinet interior before replacing any defective components. Otherwise, these same components will fail again.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
