Images obtained from the Fuji FinePix Pro S1 digital camera that are saved as TIFF-YC (also called Tagged Image File Format YCbCr or Yb). TIFF files cannot be opened with any of the programs that are native to WinXP, other Microsoft imaging programs, or most third-party software. The TIFF-YC format is antiquated and you should avoid it. Instead, save images as JPEGs (Joint Photographic Experts Group) or some other format.
In this case you would have to check the autorun settings in your finepix viewer sofware , there may be a setting which would indicate autorun or autostart for the finepix viewer desktop application , once you discover it , you would have to disable it, if not then please try uninstalling the finepix software and then reinstalling it so that it loads the default settings that was ok for you earlier.
Hope this helps ..:)
If you have any further queries, just get back to me and I would love to help you out.
Did you try contacting Fujifilm online support? This may be because you have not registered from the new computer to whatever program you are trying to connect. If your problem is about running the software already installed, why not consider using third-part software to download, and edit your photos. picasa for example.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
:You will need to connect the camera to the PC with a USB cable.
The user manual can also be downloaded from the same site above.
Please rate this solution. Thanks.
i have a fujifilmfinepixviewer s ver.2.1 i was trying to load my photos it would not load,but i saw the last five photos i took but it look like they were only scan. They disapear from my computer. Can you tell me how to get them back.
Art
okay ive had my a345 since christams and all has been good until recently when i tryed to upload my pictures. the camera when plugged in will say "checking usb" then it will say "communication error" something will come up and say "choose program to upload photos" and there isnt a program is it because i set my computer back and dont have the cd? i download picasa but it still wont upload.help please.
