Kodak DX6490, how to transfer pictures from internal memory to SD card (without using computer connection cord).
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
"computer connection cord" does this mean the camera USB cord?
If that so, there are 2 options.
1. Check if your computer has a built in card reader that supports SD cards. or (all in one card reader) It usually installed in front of your tower if desktop and if laptop usually on the side.
2. If your computer doesn't have built in memory card reader, you can purchase external memory card reader in any computer store. (usb memory card reader) There is SD card reader adapter and also there is an all in one card reader.
If this solutions solves you problem, please do not forget to rate my solution.
If not, then please comment back so I can help some more
Please do this one,
Got the manual for your camera
1. go to this link
2. look for chapter 4 (PDF file)
http://www.kodak.com/global/plugins/acro...
Copying Pictures and Videos
You can copy pictures and videos from a card to internal memory or from
internal memory to a card.
Before you copy, make sure that:
! A card is inserted in the camera.
! The camera’s picture storage location is set to the location from which you
are copying. See Choosing Internal Memory or SD/MMC Card, page 12.
Copy pictures or videos:
1 Press the Review button, then press the Menu button.
2 Press to highlight Copy , then press the OK button.
3 Press to highlight an option:
PICTURE or VIDEO—copies the current
picture or video.
EXIT—returns to the Review menu.
ALL—copies all pictures and videos from
your selected storage location to the other
location.
4 Press the OK button.
A progress bar monitors the copy process until complete. (For
information on picture numbering, see page 115.)
NOTE:
! Pictures and videos are copied, not moved. To remove pictures and videos
from the original location after they are copied, delete them (see page 53).
! Tags that you applied for print, email, and Favorites are not copied.
Protection settings are not copied. To apply protection to a picture or
video, see page 55.
! Album name tags are copied with the pictures.
