SOURCE: i get fuser error on HP LaserJet P1007
the fuser may need replacing if the error persists
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
SOURCE: hp laserjet printer p1007 engine
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
