My Transcend SD HC 8 GB memory card was showing my photos fine on the camera and on the laptop, but when I tried to save them to my laptop, I got a message saying there was a parameter error and the card needs to be formatted. I want to save my pictures before I format the card. How can I recover my pictures?
are you using your camera in tranfering your files? or you have card reader?are you using your camera in tranfering your files? or you have card reader?
You can't post conmments that contain an email address.
Make sure there's nothing in the slot, and you've got the card oriented properly. The i1237 works with SD and SDHC cards. The Transcend 2GB SD card should work fine.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
If you cannot format the memory card using the format function of the camera, please connect the camera to your computer and use the computer to access your memory card and format fromt the computer.
Alternatively you can also use a memory card reader and connect the memory card to your reader and connect it inturn to your computer and format it from the computer
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
