25cc craftsman weedeater only runs on choke. Check spark plug, change fuel lines, check muffer for pluggage, took carburetor apart and clean ,blew out, put back together and still only runs on choke. Weedeater is a little over 2 years old.
Just about to give up and trash it.
Thanks
SOURCE: weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: how to restring
Pull the spool straight off of the machine. There are arrows on the bottom of the spool indicating the winding direction. Also, there are holes in the spool. Place the line in the hole just enough to hold it while you are winding the line. Not too far, say 1/8".
Wind the outer spool first, and put the end in the notch when the spool is full. Leave about a 6" tail and cut the line. Now wind the inner spool, and place the line in the notch that is 180 degrees from the first line's notch. Leave about a 6" tail, and cut this line off. Now, turn the spool toward the machine. While holding the spool, thread both tails of line through the grommets on the machine head, and work the spool onto the head. The tails should feed out the grommets as you do this. Seat the spool, you'll feel it click into place. Tug on the ends of the line to pull the line out of the notches. You're done!
Best regards, --W/D-- please feel free to rate this carefully hand-crafted solution! --thanx!--
SOURCE: weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
