Question about Dean Vendetta XM Electric Guitar
How to higher the bridge in my dean vendetta - Dean Vendetta XM Electric Guitar
    President:
  • 1,140 Answers
Here is a link with all the info:http://www.fretnotguitarrepair.com/Electric_Guitar_Intonation.htm
Posted on Apr 03, 2010
6ya staff
SOURCE:
How to change strings on vendetta
the strings on most floyd rose tremelo systems require a small allen wrench(hex head) to loosen the pressure on the bolts holding the **** end of the string in. should be easy access from the top of the guitar. hold the guitar up to your face, **** end first and look up the body towards the neck. there should be six different screw ends visible. loosen counter clockwise. you have to trim the ball end off of a new set with wire cutters in order to replace.
Feb 20, 2012 | Dean Guitars Dean Vendetta 1.0 Electric...
I need a wiring diagram for a dean vendetta guitar
Go to either Fender, Gibson, or another guitar company, and look up wiring diagrams. Anything with 2 humbuckers and a switch is wired essentially the same.
Aug 28, 2011 | Dean Vendetta XM Electric Guitar
Whenever I touch anything metal on my guitar it buzzes, including the metal part of the 3-way switch, I have a Dean Vendetta, how do I fix this?
You have a grounding problem ! You need to BOND (electrically connect) all the metal parts including the cases and shafts of the volume controls and switches. OFTEN the cavity with the controls are painted with a conductive paint such as Aquadag or NicklePrint which is then bonded to the barrel part of the jack you plug into. Note, while this helps the buzzing due to touching the metaal parts, it will not eliminate hum if you get your guitar pickups into a magnetic field from transformers, etc.
Jan 22, 2011 | Dean Vendetta Revenge Electric Guitar
I have a dean vendetta xm and it wont make sound through an amp they wiring is correct (checked through diagram provided by dean)
can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
Jan 20, 2011 | Dean Vendetta XM Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
How to put a whammy/tremolo bar on this guitar?
This model comes with a whammy;http://www.deanguitars.com/home.php If you have the one at this link:http://guitars.musiciansfriend.com/product/Dean-Vendetta-XM-Electric-Guitar?sku=512150 You are better off saving money and getting the one at the first link. Here is why Parts:http://www.stewmac.com/shop/Bridges,_tailpieces/Electric_guitar_tremolos/Floyd_Rose_tremolos_and_parts.html Routing:http://www.stewmac.com/freeinfo/Hardware_installation/Guitar_hardware/i-1119.html or http://www.stewmac.com/freeinfo/Hardware_installation/Guitar_hardware/i-1118.html You need the tools and skills necessary to take a guitar that has a different bridge system and install a tremelo system.
Oct 31, 2010 | Dean Vendetta XM Electric Guitar
I need to wire the input on my vendetta
The positive wire is usually white and the ground is black. The ground goes on the tab that connects to the barrel that the guitar plug fits into and the positive is the tab that connects with the tip of the plug.
Jul 30, 2009 | Dean Vendetta XM Electric Guitar
Dean Vendetta XM Electric Guitar Logo
106 people viewed this question
Top Dean Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
STEVE
Are you a Dean Music Expert? Answer questions, earn points and help others
