Hifonics BXi1608D Car Amp Logo
Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to conect a hifonic amp class d to four
How to conect a hifonic 1600watt class d amp to four kickers cvrs
CHARLES JUDD
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 104 Answers
  • Posted on Apr 01, 2010
CHARLES JUDD
Expert
Level 2:
New Friend:
Night Owl:
Answers
104
Questions
0
Helped
19638
Points
255
+ too - & - too + & + too - & - too +& + too -
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Will I able to run two or four kicker competition fifteen inch subs to this amp?
  • You could effectively hook up two 15" Kickers. Make sure they are power hungry because that amp has some weight behind it. I don't recommend 4 speakers though. Get a second amp if you want to run 4 15" speakers.
  • Thanks for using FixYa
Regards, Tony
My system is running hot!!!!!
your subs are the problem, not your amp, your wiring your subs paralelle, means dropping input ohmage, allowing your amp to over heat with minimal load, check the amp specs for running at low ohms, most hifonics amps are rated 2 ohms and higher, some however will run at 1 ohm, only on class b-a amps though.(competition) dropping ohmage will allow the amp to push more power to the voice coils, however the voice coils may not be rated for 1 ohm power, what ohmage are your coils rated at? do you have a min. of 100 amp inline fuse on your 1-0 awg wire? do you have internal fans? you can add mosfets to the amp but if you do so, you'll have to re-program your amps mother board.
3helpful
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
2helpful
I have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
1helpful
2answers
I hooked my Hifonics BXi 1610 Brutus series amplifier up to my 2 12" Kicker Solo Baric L7 subs. Everything turns on on the amp but its barely pushing my subs. Ive tried tuning it and it still doesn't push...
wire the subs if thair dual 4 ohm . in parallel. red to red and black to black. giving it a 2ohm load. do the other sub the same. and conect it on the amp . turn your gain about 12oclock and db level less than 12oclock and your frequnecy around 80-100. and that should work
Can i bridge this hifonics amp
If you don't know if the amp is bridgeable, then I wouldnt do it. It could already be bridged internally and bridgeing it through the speaker terminals could be disatrous, i.e. the infamous blue smoke of death. The amp looks like a 2 channel amp fromt he pic and you have two speakers you are trying to power with it. So the safest bet would be to just unbridge your speakers and hook them each up to the amp as normal. No blue smoke. Good luck!
2 channel amp with 2 Kicker Cvrs 15"
Assuming the amplifier is 2 ohm mono stable... the amplifier is bridgeable... and the subwoofers are Single 4 Ohm Voicecoils, You would wire them as follows....
Both + on Both subs to the + bridged terminal on the amplifier.
Both - on Both subs to the - bridged terminal on the amplifier.
This will net a 2 ohm mono load for your amplifier.
If you have something different - let me know... and I will give you the proper wiring for what you have.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
3answers
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Andrew
ADMIN Andrew
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
