You could take it in to a repair shop and see if you could get it fixed, and if it is hopeless then you could get a used or new one on ebay you can get really good deals on ebay!!! Good Luck have a nice day!! :)
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off: 1: Go into the menu 2: Chose option Cam Settings 3: Switch AUTO focus to single lens and click OK.
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
normally when a memory stick is inserted the wrong way or in a speed, the contacts pins inside the cmera tends to bend. If the camera is not sensing the stick this may the problem.
