My canon powershot is showing some blank pictures that I took. It shows most of them, but mixed in are like a few that are only showing blanks.
SOURCE: Blank LCD screen
Thanks for that link, I will keep it handy! Be careful however, because the exact same symptom can be caused by a stuck shutter. To tell if it is a stuck shutter follow these steps: 1. Turn off the flash!! 2. Look down into the lens. 3. Take a picture. Did you see anything change? The opening at the center should be momentarily covered by a matte black shield. If you take a picture and see no change inside the lens then the shutter is stuck closed or open. If Canon finds your shutter to be stuck and not a CCD failure, the repair will not be free.. very not free. David Millier Advance Camera Repair
SOURCE: No image, No picture
Canon is aware of this issue and will repair free of charge (regardless of warranty status) this type of problem. Refer to Canon's website for more details.
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
SOURCE: Blank screen
Did you accidentally hit the lower left "Display" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Sounds like you accidentally pressed the DISP (Display) button on the back of your camera. This manually turns the screen on and off in picture taking mode to save battery power. You could then use the optical viewfinder in its place. To turn it back on, just the DISP button one more time.
