I'm not sure from your post above, but it appears that you are looking for a driver for your Ricoh Aficio 1027 All-In-One Laser Printer. If that is in fact the case, try the following steps to resolve your problem:
1. If your Ricoh Aficio 1027 All-In-One Laser Printer is connected to a Windows-based PC, use Windows Update to try and locate, dwnload and install the correct driver software.
The Printer/Scanner Controller Type 1027 part number is 411000 (product code B453), but I'm pretty sure that it's obsolete. Contact Ricoh customer service to find out if you can still order it.
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
