Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Posted on Nov 27, 2017
My printer won't print and the red light is flashing constantly under the ink and paper symbols although everything seems fine (there is ink and paper in). Also when I try to print there are no messages on screen to say that the printer is not working, just nothing happens. It's the Kodak all in one ESP 3. Can anyone help?
5 Related Answers
Anonymous
  • Posted on Sep 17, 2008
SOURCE: Kodak EasyShare 5100 won't print
Hi FixYa team, my Kodak printer's "Check color ink" red light was flashing so I just put in a new color ink cartridge (even though I am only printing black and white). I restarted the machine to try and print some address labels and it acts like it is printing but the paper comes out blank yet I can print pictures. I tried to print and email and it won't do that either.
Thanks.
Anonymous
  • Posted on Jan 29, 2009
SOURCE: Kodak ESP-3 Will not print calibration page. It goes thru the motions, spits out blank paper. This is supposed to happen prior to connecting to computer or installing software. Tried two printheads
I have severe and often different problems with my Kodak ESP-3 printer. Sometime it`s banding of the colors, then I`ll align the printhead and I`ll have a color problem or no color at all. I just talked to Kodak Customer Service by phone, 11 a.m. PST. After a few automated questions I had a live operator in less than 3 minutes. The service tech went thru some diagnostic steps with me and the printer and after about the 5th step determined I had a faulty printer head. If the green on/off light keeps blinking when it shouldn`t be, that is a sure sigh of faulty printer head, it means the printer is not recognizing the head. Kodak seems to be very aware of this problem and are sending me a new printer head UPS, free of charge. After reading some previous reviews I`m suprised how good the customer service was. Maybe I just called at the right time and got lucky.
Anonymous
  • 20 Answers
  • Posted on Mar 25, 2009
SOURCE: kodak esp 3 printer not printing properly.
you need to clean the printhead
Calibrate the printer (Scan + Cancel)At the same time for 5 seconds
Do a demo page ( Scan + Copy )
And go to the website :
www.kodak.com/go/esp3downloads
And download the latest version of the firmware
your all set after
Visit also the website
www.kodak.com/go/itg
for the troubeshooting guide
Anonymous
  • 1124 Answers
  • Posted on Jun 19, 2009
SOURCE: Kodak ESP 5 runs out of ink after about 40 pages
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Anonymous
  • 295 Answers
  • Posted on Jul 28, 2009
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
1helpful
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
2answers
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
I have a primera signature 4 ink jet CD printer. It will not print and the left green light on top is flashing very fast.
The printer lighting symbol indicators are messages of replaceable resources either paper or ink. usually the printer is expected to perform until a fault displays a logo either green for functionality, pink of resources shortage, and red for power resources insufficiency. Checking on the printer compartments to ascertian the conditions or replaceabel resources paper, ink, or jams due to paper over loads. Computer messages with printers would display the fault. For example, a printer message on the computer either as print job request unsuccessful or requirng software would be observable from the computer screen.
1helpful
2answers
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
2answers
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
The button that has a picture of a page and also a ink symbol is constantly flashing. there is enough ink and enough paper but it it constantly flashing and will not let me print a thing. please help.
If an Epson gets below a certain level in Ink for any cartridge, it will simply not print at all so if any of your cartridges are low, I suggest replacing them.
Red light constantly on and not printing. changed
do you print CD or plain paper, red light is mean jamed paper or change cartridge. Open the top door >press drop ink symbol> look at printer head show on ink ink tray.
1helpful
2answers
Paper in correct turned printer on red light flashing and will not print paper is blank when it comes out.
Red light flashing, do printing, paper blank out : ink low message. Ink level low, near to ink out level. But it just program, may be ink tank is out actually (no ink at ink tank). Refiil ink tank or replace w new one. Check Nozzle.
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
