Engine starts easy with choke and continues to run with choke. it does not rev up to full speed and easily dies out but will easily start again
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
