You neglected to infrome whether 32 or 64 bit if 32 bit The drivers for 32 bit are standard USB handset drivers normally provided by the phone manufacturer (LG) They use the same drivers for many of their phones.. LG VX 6100, VX 7000, VX8000 and VX 8100. Possibly even more
If 64 bit you are out of luck at this time the solution use a 32 bit version of XP without SP2 or with it maybe you get lucky and it work
ur battery is dead!!! even if u have a new phone......just plug in ur phone and take out ur battery and if it still duz it that means u killed the battery.i hope this helps a little......info by MR.GIZMO
I do not have a suggestion for you, only sympathy. I have been putting mp3s on my phone for about 3 months and there are always a few that seem to be corrupted. They will either not play or more commonly cause my phone to reboot. (even though they work perfecly when burned to cd or played through vlc or winamp) It goes to the telus startup screen and stay there until the phone flashes off and back on. I have tried re-encoding the mp3s with no change in performance. I wonder if anyone knows of a different media player for this phone. Have you called Telus? I know they are a pain to deal with but there may be options. Alternatively I might suggest flashing the firmware and starting fresh.
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
A temporary fix to the problem is to put the battery in the freezer for a minute and then put it back in the phone and it will turn on just fine! I had an LGVX8700 and it just randomly started happening one day and my fiance told me to try doing that so i did and sure enough it worked. I had to go to verizon at one point to get a new phone because the one i had got damaged and the tech there used the same battery in my phone for the new one and he thought i was crazy when i told him to put the battery in the freezer but he was in for a surprise when he did what i told him and my phone turned on. It's annoying because you have to do that everytime your phone shuts off but i always made sure i plugged it into the charger before it went completely dead.
