It stops and the 20 or 22 number blinks. It was sometimes completing the complete cycle and sometimes not. I would have to restart it. Now it stops, there is water at the bottom, clothes are soaked and the spin cycle wont get it going. At least before I could hit spin and it would work, but now nothing
Drum is giving noise when rotate by hand. During the last load, it starts to give noise during final spin.
This is usually caused by the door switch. These are fairly inexpensive and very easy to replace. First unplug your machine. To check you will need to remove the wire ring that holds the front door seal to the front panel. To do this go to the six o’clock position and you will see the spring of the wire clamp, grab this with a pair of needle nose pliers. Grab it right where it connects to the wire part of the clamp and pull it parallel to the front panel. This will stretch the spring so it can be pulled over the flange. Next carefully peal the door seal off of the flange. You do this with a sort of rolling motion towards the opening in the door. Next remove the screws that hold the door switch in place. Make sure you have one hand supporting the switch assembly while removing the screws. Now pull the whole assembly out the opening. Mark wires if you need to and then remove the wires. Now connect your ohmmeter to the 2 wire on the bottom you should have a reading of 1500 ohms no less than 1400ohms. If it is below the 1400 or more than 1700 replace the switch. To reassemble reverse the order of disassembly. Making sure the little arrow on the door seal lines uo with the mark on the front panel. The spring can be a little trick to get back on but grab in same position as removal and use the other hand to push it over and around the seal. If it is within this range the main control board is at fault. Not inexpensive. You can enter your model # at www.appliancehelponline.com to view diagrams and illustrations of your specific model. Not all models are available.
