Check the surround setting you may have these HDMI channels set on. Try changing the audio setting to STEREO to see if you still get the OVERLOAD message. If it helps you may have faulty wiring on your surround speakers. This would explain why it was only happening on your HDMI settings.
After checking your wiring and not finding any problems you will have to narrow it down to the source of the problem. Disconnect your center channel and retry the surround mode and see if you get the OVERLOAD.
Once you find the problematic speaker you may need to replace it. Unfortunately it could be possible the speakers are unable to handle the power being provided by the receiver and may be sending feedback to the unit causing it to overload.
