How to fix error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
SOURCE: 6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
SOURCE: Canon MP850 error code 6A00 flashing lights. no
Hi
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
SOURCE: Canon Mp780 error code 6A00
6A00 is not a jam error, it is an error of the purge assembly not cycling properly. Many times a paper scrap jammed in the capping assembly or the squeegee assembly caught on the filter assembly. Usually worn out gears and dried ink so that replacement of the purge assembly is the best fix.
SOURCE: Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
SOURCE: cannnon mp-530 shows 6a00
Hi
This is same as the wat full
Solution 1:
Solution 2:
Solution 3:
