12v DC 0.5 Amp.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
I'm guessing you want a power supply and the install disk. The power supply and shipping is worth more than the router. I would buy a new router. The drivers can be downloaded here. You will need to enter your hardware number to get the right download. The correct power supply is 12volts, .5 amps. Watch your polarity and plug internal diameter.
