SOURCE: I have a Husqvarna Yth 180, the lawn mower shut
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
SOURCE: Mower Runs briefly then cuts out and wont restart.
These ride-ons have a cut out solinoid under the carby that when there is no power or the ign is cut it will drive a little pin into the main jet to prevent flooding, id say this is why your mower runs for 20 and stops...
There is a few reasons this could be occuring:
#1First I would be checking the battery see if its dropped a cell or has a dead cell, you can do this by load testing it with a load tester or removing it and taking it into a battery specialist. if this is the case the battery will not accept a charge from the charging circuit...
#2 Check your wiring with a multimeter from the armature under the flywheel all the way back to your battery (also these models may have a regulator/rectifier that can be tested they have test values and can be checked by your local small engine repaier)
#3 If all your wiring is ok then you will have a problem with your armature this is located under the flywheel on your engine it has two seperate windings one for the charging of your battery and the other powers your headlights / elec magnetic clutch, the one for the charging will be unservicable these can be diffucult to access and test and is probably best done at your local small engine repair shop...
Hope this helps you out
Kind Regards
Brad
SOURCE: belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
SOURCE: Help! My Husqvarna YTH 2046
Hi and welcome to FixYa, I am Kelly. I am looking for your service manual but beed to know if your mower has a number on in ending in 3300, 3301, 3302, 3303 or 3304. An example of the number I need would be like this: 96043003300 The 3300 series numbers above are just the first 5 of 10 models.
There are 10 different service manuals for this mower and my best guess is the model number is something like this: YTH20K46
I think you have a blown 30 Amp fuse but need to find the location in the manual so I can pass that to you.
There is the possibility that the engine alternator has also failed also but, you said the LED was blank and the mower does nothing so that in itself points to a fuse / wiring issue.
From what I can tell the fuse is a flat bayonet type fuse and should be located on the left side of the mower about 6 inches in front of the mower deck looking from the top. I just can not tell what elevation the fuse is at. This fuse is in the circuit between the battery and the Amp meter. A second look for the fuse and it appears to be in the exact area even with the left foot pedal. Look in that area vertically for the fuse.
Thanks for choosing FixYa,
Kely
SOURCE: I have a Husqvarna YTH 150 riding mower probably
I guess one could do a google search for "husqvarna mower parts", that brand is really made by AYP so you may want to search that too. When you search you get links to sites selling that stuff, you look at their web pages and see if they have want you want, if not then go to another link and hone your search.
Frankly what I would do is take the plastic pipe to a small engine/mower repair shop and ask them where they would find a piece of pipe to replace it. It most likely does not need to be clear, so about any like diameter plastic pipe cut to length would do and would be much cheaper than trying to track down and pay for an OEM part. Hardware stores often have various sizes of that stuff laying about to make into drain and sewage systems.
