SOURCE: Maytag atlantis electric dryer
Sounds like the moisture sensor has gone away. Not sure where it is located on this model, though.
SOURCE: Stopped mid-cycle
I have the same problem.
Model: LAT2300AAE
Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
SOURCE: Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Check the water level control, it could be stuck or faulty.
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
SOURCE: location of filter on maytag performa heavy duty washing machine
I'm sorry Hilda, most washers that have been put out over the last several years don't have a filter per se. When the wash cycle agitates and lint is released from the clothes, the outside of the basket (the area where you put your clothes) is very sharp where the holes are. Lint collects on these holes as the linty water flows through them. When the rinse and spin cycles dis-lodges it and send it down the drain.
There are some availibkle aftermarket kits availible at some appliance parts stores. They are generics and not produced by the manufactues, but if you wanted a lint catcher n a washer, it would be an option.
I hope this helps with you questions. If you have any other quiestions or concerns, please feel free to write me back.
