Question about Sony Audio Players & Recorders
Hissing and Humming when trying to use the speakers for the tv
I have just bought a Sony DAV-DZ280. Why do i get a lot of static sound (hissing) and humming when watching tv through the sound system?
    New Friend:
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Posted on Oct 18, 2010
6ya staff
SOURCE:
F/r and r/r speakers no sound just hissing
either adjust the balance on the speakers or you need to switch the wires. one is in the red and one in the black. switch them around.
Feb 28, 2010 | Sony DAV-S500 System
Sony Surround Sound, LG TV and PS3 connection problems
sounds like you are going to have to get the component cables for the PS3, you can get them on amazon, the only thing about the component cables is that the quality cant go as high as the HDMI cable but its close. but thats the only way i can tell you to have surround sound with your PS3
May 09, 2009 | Sony Playstation 3 (PS3) Console
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
Hissing Noise
this is a common problem and all you really can do is to turn the speakers off when you are not using them which is also good for your energy bill!!!
Jun 11, 2008 | Sony DAV-C990 System
Speakers hissing/humming
Hi Nate41
you won't do anithyng
may be is a bad resistor inside, that get hot and probably start to do this problem. try disconecting the speakers, and move to other place, more cooler, and try to see if you don't get the hissing and humming sound now. sometimes dust and hot places get to this problem.
beside that, may be a path to a problem.
Nov 26, 2007 | JBL CREATURE II Computer Speakers
Static or hiss noise
I have the same problem. Only one speaker is hissing and only for analog sources. No hissing when I select Coax.
Nov 14, 2006 | Harman Kardon AVR 340 Receiver
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
327 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
