Question about Gateway Computers & Internet
How do i run my computer to my tv. I hooked it up through HDMI and it shows my background but nothing else.
  • Anonymous Apr 05, 2010
    that didnt help any other ideas?
  • Gateway Master
  • 6,063 Answers
Your monitor and your TV are currently screen 1 and screen 2 with screen 2 as an extension of screen 1 (you can move your mouse all the way across and see it come over to the TV screen). With Vista or Windows 7, right click on the desktop (no icons or programs) and choose Screen Resolution. There you will find options to change your screen output. (The choices are fairly straight forward - both screens identical, screen 1 or screen 2.) For XP, the right click on the desktop will get you to the point but I think it was called Display Options.
I hope this helps.
Posted on Apr 04, 2010
  • Cindy Wells Apr 05, 2010
    Again what OS are you using? Then I may be of more help. (Just walked over to the laptop with the 2 display setup - Screen Resolution, Multiple monitors (Win7).) Once that was set up, there is actually a quick three simultaneous key strokes command to switch back and forth (F1 for external monitor, F3 for the laptop monitor - single screens).
    The Control Panel Display options is another place to set up the monitor arrangement. What graphics card driver are you using? I can't rule out that you need to adjust something in the graphics controls. (My ATI drivers (desktop) and my laptop's (intel drivers) are also accessible with that right click on the desktop.)
    BTW, did you reboot after connecting the computer to the TV with the TV on? At least on my older computer (still running Win7) the plug-and-play drivers don't synch and let me swap monitors until I reboot a second time.
6ya staff
SOURCE:
GET MY COMPUTER TO SHOW VIDEO
If you did connect the computer to the tv with a HDMI cable, you have to look there. HDMI also protects giving through copy protected content. Please read everything about HDMI and digital rights.
Oct 29, 2014 | Audio Players & Recorders
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
I switched my ps3 from one tv to my vizio, and the voices of the characters arent being heard, but all of the background noise is. i have it hooked up with an hdmi cable, and the video is fine. i checked...
Shot in the dark here, but sometimes HDMI cables get a little discombobulated... Try doing a hot plug by powering both the TV and the PS3 up and then removing the HDMI cable from both of them at the same time. Wait 1 minute, then plug them both back in at the same time. Good luck!
Jul 21, 2011 | Vizio M221NV 22 in. HDTV LCD TV
Trying to hook up my panasonic tc-p50c2 to comcast hd digital cable box and cant get it to work with hdmi cord..nothing is showing
Use only the hdmi cord to hook it up and go to menu on the tv and select hdmi for hook up and you should get a picture. Make sure your cable cord is the only cord running to the cable box , you don't need any other cord.
Feb 09, 2011 | Panasonic TCP50C2 50 in. TV
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
Hdmi to panasonic tv no desktop display only
I can help with getting your desktop onto your TV, but sound from your computer through HDMI can be much trickier.
If you only see a background picture on your TV, then your desktop has been either "extended" or "stretched" onto it. It is essentially a second independent monitor and you can drag applications over to it to see them.
To view your desktop and start menu on your TV, you need to run ati catalyst and "clone" your TV with your computers monitor. Do this by right clicking the picture of the second monitor in the catalyst display manager and choosing "clone". Now your tv and your monitor act as one.
Although i tried 3 different ati cards with hdmi outs that claimed to pump audio through hdmi, none of them worked for my HP PC. You will need a grey widget adaptor between your computer and the hdmi cable. In the end though, there's a conflict between my sound card and ATI's HDMI audio that cannot be resolved. So I run a digital SPDIF signal instead through an rca cable and get 5.1 dolby at my amp that way. Good luck.
Sep 20, 2009 | Acer Aspire 3000 Notebook
Hooking Sanyo TV up to a computer
you need a hdtv tuner Hidef is different format than the rca jacks and digital won't worrk sorry.
May 24, 2009 | Televison & Video
How to hook up a hp pavilion laptop to a hdtv
if it worked fine at some point then it should work fine now... i use hdmi to hdmi from my laptop to tv all the time dvi would only cause quality loss.
the first thing i would try would be to change your resolution on your laptop to a couple different settings. a lot of times, if its not set to one thats compatible with your tv, you won't see anything.
if that doesn't work, go to personalization and open the tab that says "connect an external display" and toy around with it. but yeah it doesn't sound like you have any hardware problems there.
hope this helps
Jan 16, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
103 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
