How do i get the pictures too upload onto my lap top?I have done it before but now when i connect the camera and lap top with the usb cord nothing happens.
Sorry you are having problems. To fix this we need to verify some things Does windows tell you it has found a new device when you plug the camera in? In Control Panel, System, Device Manager can you see the camera listed? Does it have an exclamation mark next to it? Do you use the USb cable for other devices? Are they detected when you plug in the cable?Sorry you are having problems. To fix this we need to verify some things Does windows tell you it has found a new device when you plug the camera in? In Control Panel, System, Device Manager can you see the camera listed? Does it have an exclamation mark next to it? Do you use the USb cable for other devices? Are they detected when you plug in the cable?
You can't post conmments that contain an email address.
if the kindle device is like an i pad then the connection can be either wifi or by the charge cord that has a usb port on the end
there are how to pages on the net as to how it is done
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Your USB cable is fine, I use a generic cable with my A590 with no problems. Connect the USB cable to the camera then your computer, make sure that the camera is set to the view setting instead of picture taking setting and then turn your camera an. Your computer should then see the camera. This is the only combination that works with my camera.
I can'tg upload pictures. I have a polarioid t11031 digital camera, and I have a USB cord ffor it, but my computer does not recognize it when I plug it in. I want to know how I can get the pitctures off my camera and onto my computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
You are having problems...what sort of problems? Have you tried putting the USB cord into a new port?
If you could provide a little additional info, I might be able to walk you through it.
USB can be funny some times- it has worked so you know what to do OK?
Check-the USB setting- Start/ControlPanel/System hardware/device manager
Rund down to the USB setting and open it check for any yellow makers intcatiing afault - seek help from there.
If you are using a hub or have multiple other devices connected.- disconnec them and use the USB cord direct to computer.
Have you remembered to switch the camera on- it has good batteries- set to upload Huh!
So much to remember easy to forget something
If the trouble wont go away- go buy a card reader and leave that lugged in to usb.
