Epic Overstock  T60 Treadmill Treadmills Logo
Posted on Apr 05, 2010
My epic T60 will go great for 10-15 minutes and then
My epic will go great for 10-15 minutes and then shut off. It will only go for 30-40 seconds after that for an hour?? Is it getting overloaded?
Anonymous
Level 1:
Scholar:
  • Contributor 34 Answers
  • Posted on Jun 07, 2010
Anonymous
Contributor
Level 1:
Scholar:
Answers
34
Questions
0
Helped
30585
Points
78
These treadmills have what is called a thermal switch. It is designed to shut the machine off if it gets too hot. To help this problem you can purchase some treadmill lubrication. It is a waxy based substance that you put on the underside of the walking belt. That is the most inexpensive alternative. You may need to purchase a new walking belt. How you can tell if yours needs to be replaced is to put your hand on the underside of the walking belt. You should feel a texture like a screen door if it is in good condition. When you pull your hand out it should feel like you have been eating popcorn, a little greasy. This will prevent the overheating problem and not shut your machine off in the middle of workouts.
Motor starts and shuts down within 2-3 seconds and will not operate belt.
If you wish to get some details; check the site linked here. Pull up older posts for treadmill . Surf the site with patience.
http://electro-medical.blogspot.com/
Motor starts and shuts down within 2 seconds. About 12 years old
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Treadmill loses power all the time
see the video and fix it. +LUBE the rollers bearing front and back,+test the drive belt motor too.and replace if necessary.
God bless you
1helpful
Treadmill- Epic T60. Immediately starts of at full speed and causes circuit breaker to trip
Hi There,
This problem could be a faulty speed sensor . Especially with optical speed sensors. The other reason could be a faulty LCB ( MCB)
5helpful
I have an Epic t60. The incline stopped working. I was in the midst of going from flat incline to full and then back down again when it stopped. The incline numbers now register on the display, but it...
Try to recalibrate the incline. Start the machine running, press the incline up button, then pull the safety key off. Release the incline up button and replace the safety key. The treadmill should go to maximum incline then minimum. after calibration is completed, retry the treadmill operation.
Tread skips or stops when running
On my Epic you can adjust the belt tension by using an allen wrench in the holes on the end of rails. Tighten 1/4 turn on each side and see how the tension is. Repeat another 1/4 turn if necessary.
3helpful
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
