2006 Toyota Corolla Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a squealing sound coming from the engine on start up and when sitting idling. Is it the serpentine belt or are there other reasons for this. Is that the only belt on a 2006 toyota corolla automatic.
Kiri105
Level 2:
Sergeant:
  • Expert 286 Answers
  • Posted on Apr 05, 2010
Kiri105
Expert
Level 2:
Sergeant:
Answers
286
Questions
Helped
122656
Points
739
Check tension the drive belt(s) as slipping at low rev is a classic indication of this fault. In extreme conditions a rubber burning smell may be present. Replacement of drive belts is the 100% remedy and best option .
Do serpentine belts stretch?
serpentine belts do not stretch as you describe because the tensioner keeps them tight so they just break. It is probably hard and cracking and need s a new one so try that first . The ac has nothing to do with the belt as it will be a low gas problem from leaks and the heat is a coolant problem or a control problem from inside the car.. The grinding sound may be a pulley bearing or some other bearing failing. Why don't you take it to a repair shop to find all the faults so that you can work out how much it is going to cost.
2answers
2002 Ford Mustang pulley squealing
Replace the crank pulley before it costs you an arm and a leg. It has caused this problem. don-ohio
Squeeking idle
Tensioners should be replaced about every 80 thousand km when u let of the gas it relieves tension on belt tensioner if the spring inside is wearing out chances are there's ur squealing sound would sound like a belt squeal not a bearing
1helpful
2answers
When car is running idle or at slow speeds it makes a squeaking sound
There are several heat shields that can squeak or you could just need a new serpentine belt. Unfortunately, a lot of things can cause a 'squeak' but without knowing what area it comes from, if it changes with engine speed, or vehicle speed, I can't give you any pinpoint information.
2helpful
Engine making noise
Based on what you described, sounds like the bearings on one of those items are worn out. Is it a squealing sound??
Another thing, is maybe your serpentine belt is just loose or old. You could go get a can of belt dressing and spray on the ribbed side of the belt, as it is idling.
1helpful
Everytime i accelerate my car it starts making a squeling noise but when i don't accelerate it stops and then i hit the acceleration again and then again noise starts and i can't seem to find the problem!
Are you sure you don't hear anything like a chirping sound when the engine is idling? Have you popped the hood and listened while the engine was idling? Have a friend sit in the driver's seat while you pop the hood, tell them to press the accelerator and then listen for the squeal. I would bet dollars to donuts the problem is the serpentine belt is worn and needs to be replaced.
1helpful
Van brakes squeal/whistle even when stopped
Sounds to me like a dry, loose or worn serpentine belt. With the motor idling, lightly spray the serpentine belt as it's spinning with WD-40 or other oil based lubricant (Don't spray near the alternator). If this doesn't work, turn the mortor off and check the tension and for cracks or worn spots. The brakes will not squeal when you are completely still.
High pitch squeeling sound at start up and while idiling coming from engine area
the squealing when you start it and are idleing s probably the fan belt or serpentine belt, it may need to be replaced or it could be that it needs some belt dressing sprayed on it. belts will squeal if they are damp from the moisture in the air. as for the fan you most likely have an electric fan in your car and they sometimes run for a few seconds after you shut the vehicle off. It would be a good ideato have someone ceck the fan for you and the belts to be on the safe side.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
