I have a Norelco 835rx which I have not used it in 10 years (it worked then) I just cut my beard last night so got it out to shave the stubble. Plugged the shaver into a cord I think is it's, which says 125v 10A, and it worked last night, left it plugged in to charge, this morning it was warm but only turned slowly. I used it a little, then unplugged it to cool. 2 hours later it does not work at all, plugged in or not.
The battery pack is, likely bad and will need replaced. Batteries don't hold up well sitting around for 10 years. The stress of charging may have finished off the batteries completely. When the batteries short out internally, the shaver wont run from the cord either. Before ordering batteries you'll want to make sure the old ones have not corroded badly and ruined the circuit board. To check it out, remove the four screws on the back and remove the back cover. Lift out the circuit board and inspect it to make sure there are no burns.
If everything looks to be in good shape, installing a new battery pack will probably be all you need to do. You will fin the correct battery pack at shaveroulet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
