Bosch 18 in. SRS55L02 Logixx Slim-Line Free-standing Dishwasher Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blocked drain my bosch srs55co2gb is blocked
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Apr 10, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126552
Points
799
Try to disconnect the drain hose under the sink and put the machine in drain mode this will **** the water out of thge hose. if the water is blocked in the machine you have to get a torch screwdriver and take of the plastic piece in the center of the unit . that is where the propellor is. then close the door and put the machine into drain. the stuck partical should reverse out.then place cover back on.that should do it
Hi - bosch integrated dish washer has just stopped draining - liquid in bottom - nothing happens even when I turn electric off....
Hey Karen, Water in the bottom of the dishwasher results from clogs in the filter or in the drain hose. Before you do any work on your dishwasher, make sure that it's switched off at the mains. If cleaning your filter hasn't resolved the issue, then the next thing that could be preventing your dishwasher from draining is a blocked drain hose. Is your dishwasher displaying an error code? If you see the E25 error code on a Bosch dishwasher, that means the filter is blocked or clogged, and water cannot drain out of the machine correctly. You can check all Bosch dishwasher codes here: https://www.justfixed.co.uk/bosch-dishwasher-error-codes/
Best,
Dave, Just Fixed
4answers
Bosch dishwasher stopped working after few minutes. And LED displayed E:24. What is the problem?
Fault Code E24
Symptom: Dishwasher not draining properly.
Cause: Drain filters blocked.
Action: Clean the filters.
Go to:Why is My Bosch Dishwasher Not Draining?
For more detailed codes see ...
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Bosch dishwasher does not drain water and does not run
Bosch,. like many others have a "safe: cycle where the machine will always do a short pump out before it starts any cycle. If it fails to do a pump out even if there is no water in the machine, the machine will go into safety mode and will not allow a program to start. You will have to pull the machine out and check if the drain hose is blocked or kinked, and that the drain pump is not blocked or jammed. Toothpicks, bits of food and broken glass fragments are good for blocking / jamming dishwasher pumps.
Error E:25 on bosch dishwasher smv53A00gb/24 what does this mean
E25
Drain pump blocked or pump cover missing
This can be caused by the above or by, as the fault code indicates, a blocked drain pump.
Dado
Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Unscrew anti-clockwise to remove and clean.
1helpful
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
1helpful
2answers
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
2helpful
My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
