Canon PowerShot A95 Digital Camera Logo
Posted on Apr 05, 2010
Picture color is pinkish and out of focus
Picture color is pinkish and slightly out of focus, the view finder is clear and shows accurate colors.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
294
Points
0
There might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
1helpful
When I look through the viewfinder on my Nikon D40x it is blurry and looks out of focus, but when but after I take the picture it is clear on the lcd screen. Is there a setting I can change or is something...
Adjust view finder focus as you will see setting there, to view correct focus in view finder itself.
Camera is just fine because it is taking good focus pictures.
Picture in view finder and LED screen jumpy and not in focus
Is there fuzzy color? pink and green? if yes, then it's 99 percent for CCD fault.
1helpful
My Olympus SP-350 cannot focus, wierd colors in the LCD screen
We took it to a camera shop,and found the sensor was blown.
2helpful
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
1helpful
Picture in View Finder perfectly clear, but out of focus
I would check IS(image stablization) setting and continous shooting setting to make sure these features are turned off. You want to experiment with different IS settings and definitely turn the continous shooting mode because the continouse mode may not focus 100% in order to shoot multiple shots. Hope this helps. -James. P.S. In my case it was too difficult to distinguish the quality of focus in the VF or LCD so you may not see the focus issue on them.
No clear color
i had the same problem a year ago / this is not somethin you can fix by yourself
you shood get your camera to a laboratory that repares sony's camera because there is some chip they need to replace - if i recall somethin likr color mannager\spliter i don't have the wright words in english for this
1helpful
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
1helpful
2answers
Fuzzy photos
Turn the small dial to the right of your view finder either "+" or "-" until picture is clear inth eview finder
2answers
Blurry, streaked picture through view finder
Good Day, is the blurry picture pinkish in color? It might be an imager(CCD) problem, you can check it at sony support website, if it qualifies, just read the provisions, I will not comment on the policy, maybe it differ from country to country, i'm here in the philippines. thanks
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
