I am looking for the output cable (for both audio and video) for the JVC GR-DX97U. It connects to the camcorder output and has at least a left and right audio RCA cable, and a composite video cable. (3 output cables)
The other version has the above and an S-Video cable and a connector for the remote. (5 output cables)
I have heard there are the two cables. One has just the 2 RCA audio cables and 1 RCA Video cable (3 outputs).
The other cable has an additional output of the S-Video cable and a connector for the remote.
I am looking to see if you have either of these parts and how much each one would be. Also, what would the shipping cost be?
Thank you!
SOURCE: JVC GR-DVF31 - How to transfer MiniDV to PC?
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
SOURCE: Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
SOURCE: Connect A JVC GR D31 Camcorder to a Computer Via USB 2
Well I'm afraid not the cable don't not come in such of a way either cause they are different type of cable, but what u can do is buy an external fire wire card for yr PC it comes in PCI format for yr desktop PC. because camcorder in these days do not use USB cables due to the cause that fire wire cable is much faster than the USB ones.
SOURCE: cannot find driver for jvc GR-D720 Mini Dv digital camera please help!
If it's a JVC GR-D72, then it's MiniDV. Connect the camcorder via firewire to your PC
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
