Briggs & Stratton Montgomery Ward Power Kraft All Season lawn mower, model # TMO-37341A, Serial # D272A...This lawn mower came w/ the house, and it worked good the first few times, but wont start now. I would like to fix it myself but cant find any information or manual on this particular model. I called Montgomery Ward Customer Service, hoping they would have answers, but she was no help. (Montgomery Ward doesnt even make lawn mowers anymore) I am 100% positive that the model/serial# is correct. Please help...
You need to obtain a manual for Briggs & Stratten engines. All the info you need will be in it. The most common cause for non starting in these engines is "Tight Tappets" Wether it's an OHV or the old "L" head engine, because they rev and work so hard, the valves seat themselves deeper into their seat which reduces the valve clearance. There is no adjustment on the older "L" engines, so you have to remove metal from either the valve stem, ot the lifter itself. I have in the past done this in situ with a point file, but it is a tedious job. Otherwise you must remove the head and take out the valves and grind the stems. A tricky task and probably should be done by a mechanic.
