F02 is listed as a motor jammed or tacho failure.Check whether the motor
is not siezed or damaged.Try turning the drum by hand.Check the following
1.Does it turn easily and freely.
2.Are there any strange noises from the motor area.
3.Check for broken wires from the motor plug to the main control board.
4.Check the main control board for signs of damage or burning.
5.Check that all plugs are firmly seated on the control board and into the motor.
This requires a technician to attend to this problem.
Check that the motor is not siezed or damaged. Try turning the drum by hand. Does it turn easily and freely? Are there any strange noises from the motor area?
If there's nothing obviously wrong I'd check the carbon brushes in the motor.
After that, if it's all checked out ok, time for the engineer.
As it could be costly on parts, ie. possibly a motor and a main pcb.
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
-----------Transmission fault light on
car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
--------Transmission shifting
problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
--------Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid
leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into
reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
----------Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
-----------This will help.Thanks.
